Has anyone ever put in coil packs to replace the distributor? I'm doing an engine swap and have to replace the ecu with an ignition system and would like to keep it neat. I don't want to run spark leads from a wasted spark module because of the space the module uses. The klde V6 is in a RX8 so I need the room for the lpg system that's going in. Any advice on what coils would fit in would be nice, the length is important as it needs to clip on and seal from weather.
Vendor
A lot of our MegaSquirt customers have done this. You will need an ECU with at least three spark outputs (three would fire the coils in pairs) to go to coil per plug.
