hi guys
my engine is coming up with a knock sensor fault
I ve replaced the sensor and still coming up with the fault
so I replaced the ecu and still coming up with the same error code
knock sensor, I think the wire from the knock sencor must have damage or pulled out of the ecu plug or something
dose any one know where the knock sencor wires go into the pcm
what pins ?
thanks guys
Super Moderator
Hi
I know that sometimes the wires get crushed or pulled it at the connector. Have you checked to see how the connection looks?
A quick way to test the main lead off the harness is to test it with a multimeter. If there is voltage that is good. You may have bought a bad sensor
Discussion Starter #3
g that would suck if its a bad sensor ill check the plugs again just to be sure thanks
dose anyone have a wiring diagram for the ecu's or car
that would be good to look over as well
thanks for taking time to reply twopedlewarrior
