Found a used KLZE 7 nipple disti cap at the wreckers the other week for my HEI project. Will this work? The firing order is different, but i suppose i can just copy the ignition wire pattern from my previous cap?
I have everything for the conversion now :) hoping the ZE cap will work. Just have to find the time to install it...damn winter.
JACK.
Discussion Starter · #2 ·
just to make certain
cut 3 pin plug & wire it to the HEI.
3 pin plug 1 - 2 - 3
HEI module B C C
1k ohm resistor
The other thing that has confused me...i own a 93 626 v6. I keep seeing multiple differences where the #2 wire on the 3-pin goes. I've seen it go directly to the HEI @ pin C. I've also seen the resistor wired into #3 then spliced into #2 then go to pin C.
JACK.
The ZE disty cap does NOT fit onto a DE disty. You will need the distributor for this to work. And the firing order is the same, the difference is that on the DE 2 of the contact cross each other. Flip the DE cap over and look inside, you'll see what I mean.
crap, so i can't use it. well that kinda sucks...guess i have to modify my brand new cap...hope i don't fuck it up lol.
JACK.
