OK I read the KLZE faqs but it really didn't tell anything about my problem i'm having. Ok i'll start off with the trials we did. I got a KLZE from one of the members but it didn't have a tag on it but he said it was a KL31. And i read that it will only work with the JE50 MAF/VAF. Well when i put in the KL31 ecu and the JE50, i hit about 5000 rpms in 1st gear and it starts jumping or studdering. So i drove it around a little bit thinking that it had to adjust but it keeps on doing it. So my brother has the KLDE (the american engine) in his and we thought maybe the JE50 would work in his and it did (not sure but should the JE50 work with the American engine?) And then we tried my original KL02 VAF and it worked with the KLZE ecu. Now i don't know if the JE50 is bad or the ECU isn't a KLZE ECU. Tried these tests and got no where. Do you have any suggestions on this problem i'm having. I also noticed the KL01 ecu i had in the car has the yellow male connectors and the one i got (KL31 ECU) has dark grey male connectors. Not sure if this means anything but just trying to get to the root of the problem.
Thanks,
Mario
Thanks,
Mario
