· Registered
i have a 93 mx6 w/ a klze engine and jdm ecu w/ je50 maf.
so i reinstall the kldes' ecu and the codes that im getting are:
16 - egr system
26 - canister purge solenoid
28 - egr vacuum solenoid
29 - egr vent solenoid
69 - ECTF sensor
i know that all the egr codes are expected, but what about the canister purge solenoid and i believe the klze only has one plug for the fan so that means my car will have a plug for the ectf sensor that will not be plug therefore 69 is also expected.
however, i dont see a a solenoid for the canister.
· Registered
thanks
The canister purge solenoid is hiding up near the TPS and throttle body, or it should be anyway.
ok, i'll look again but i swear i didnt see anymore solenoid back there.
What do you mean one fan? My front cut had two fans?
sorry, i meant the ECTF (engine coolant temperature - fan) the 94 and up only came w/ one ECTF.
thanks, i'll keep you posted.
