1 - 11 of 11 Posts
· Registered
Hi
A couple of days ago i posted a thread, where i was wondering what kind of engine do i have.
I have checked my engine and I found the folowing numbers on:
on the part of the engine which is closer to the front it says: KL31 1A1
And on the other part which is closer to the rear it says: KL31 101
I would really appreciate it if someone could let me know wheter it's a klze or kl03 engine i have.
Thanx
Janos
· Registered
for a KLZE.. One should read KL31-101 and the other KL31-1A1
but you mak not have a compleat swap .. what does the intake look like?
this..?
· Registered
I'm sure now that the engine is the j-spec since also the oil filter i have to use is different from the a-spec engine's.
I'm very happy to find out that i have a KLZE
I'll change the im and the vaf and ecu to get the most out of it
Thanx for ur help
Janos
· Registered
Well you have at least got KLZE heads.. If you want to check your pistons just get a flash light and look down a spark plug well the top, of the piston should be flat .. have a look @ the KLZE FAQs in the performance forum..
· Registered
I'll check the pistons tomorrow, since tonight i won't c a thing, but i am quiet sure the whole engine block is j-spec not just the headers, since oil filter is also the j-spec, but i'll check the pistons just to be [email protected]
I do feel like a lucky bastard now as u mention it})
Janos
· Registered
Thanx for ur help
Janos
The OIL filters are different????
Umm, my ZE and 03 run off the very same filters....
· Registered
mmmmmm.... interesting!!!
I think you have a ZE head (not header... BIG difference between those two things) with an a-spec IM.
I have a ZE IM I need to hock. To bad you don't live in Texas!!!
· Registered
About the hocking im
Hi aggiedj02
What would u want for ur im? I have a friend in Huston, he could get it to me and we can just wiretransfer the money.
And i'm sorry..I ment as head not headers:D
And yes my a-spec 03 used a different oilfilter than now my klze uses (i'll check the number on the filter).
Janos
1 - 11 of 11 Posts
