Status
Not open for further replies.
Im looking to swap my BLOWN!! stock MX-6 V6 egine with a KLZE J-Spec engine... Is there anything else i need to install this new engine into my car? Will the stock ECU work witht he KLZE? Will the stock tranny fit the KLZE? I've seen that i need to buy a CAI (hotshot)?... is this true? if ANYONE can give me ANY information about this project.. Please feel freee to drop me a line...
Thanks...
Serious HELP NEEDED..... ANY INFO PLEASE!
A KLZE is basically a direct drop in. You may have to redirect and change the length of some the vaccum lines but it should bolt right up to your transmission. Depending on the year of your car you may have to change the ECU, or have your current ECU modified. Do a search on KLZE's or look in Lorn's post to find the links I provided and you should get some valuable info on swapping a KLZE for a KLDE. Hope that helps.
Status
