Exactly what does 'pinging' or 'knocking' sound like? My knock sensor is dead and I am waiting to find a place to replace it cheap... I don't think I have heard pinging or knocking but should I not drive much until i get it fixed?
About how much will a knock sensor cost?
The CEL only goes on when I am in a lower gear than needed.. (rpm's just above 2000) and usualy for a short bit and then it goes out... it goes back on and off if you stay in that gear.
The conditions most likely to cause detonation are at low RPM, under high-load with crappy gas: put the car in 4th gear at 30MPH and floor it. If you hear something that's vaguely like marbles in a tin can, that's detonation. You may only hear a hint of it as you put the pedal down.
In small amounts detonation won't hurt a normally aspirated car. However, prolonged detonation can cause problems.
I can't say how much a sensor will cost but it's likely not cheap and replacing it is tough: the intake manifold and a coolant pipe must be removed from the V6 to get at it. Have you actually pulled a code 05 from the PCM?
Finally, when the PCM senses a bad knock sensor (e.g. the sensor is shorted to +5 or to ground) or if it hears a ton of knock activity, it will revert to using a spark table that has much less advance under low RPM/high-load conditions, precisely because of your concerns. If this is true, you may not hear knock under the conditions I mention above because the PCM is using the low-advance table.
five short flashes
Well when I pulled the trouble code it was 5 short flashes which i was told was the knock sensor.
What would you reccomend doing? should I take it to a shop? I really don't want to spend that much money.. but I don't want to have to rebuild an engine!!
Thanks for your help
alex
