hi. discovered a leak at the rear brake caliper. looks like its coming from the pin that connects the parking brake cable to the caliper assembly. i have removed the cable and spring and the pin moves up and down and leaks when i move it. i see a rubber gasket and pin looks corroded. my question is how do i remove that pin? it swings back and forth but there is another pin that acts as a stop for the cable . this pin prevents the assembly to be fully removed . anyone understand what im trying to explain?
my original 93's rear brake calipers leaked also. I swapped them out with the calipers from my 96. it was pretty dangerous when i was going along and then step on the brake and oh shit. if stuff is corroded in there, might as well get some remanufactured calipers to be on the safe side.
