List all of your mods. here. And what mods. you want.
  • Turbo
    Votes: 14 20.9%
  • Nitrous
    Votes: 2 3.0%
  • Flywheel
    Votes: 1 1.5%
  • Air Intake
    Votes: 3 4.5%
  • Fuel system (Including fuel pump, injectors, and filter
    Votes: 4 6.0%
  • F2
    Votes: 7 10.4%
  • FE3
    Votes: 5 7.5%
  • FE3T
    Votes: 12 17.9%
  • F2T
    Votes: 14 20.9%
  • Lightend body.
    Votes: 5 7.5%
21 - 40 of 77 Posts
my list
i dont hav much done but im gettin there pretty fast!!!
where should i start???
1992 Ford Probe GL
Engine: vaf adapter w/ K&N filter, Custom ram air intake, MSD Blaster 2 coil, 96 Rodeo fuel filter (upgrade), 4 guage wire on some of the ground points, 2 1/4 inch exhaust pipe w/ractive muffler,
Suspension: Intrax springs (about to be changed to Eibach), Monroe MacPierson struts, PGT strut mounts,
Weight Reduction: Backseat taken out, Rear trunk panels and excess pieces taken out, Front crunch bar taken off,
Interior:Alpine 9827, Panasonic 6 1/2s (Front), Panasonic 5 1/4s (Rear), Mazdaspeed shift knob, Autometer A/f Ratio guage,
Exterior: 89 PGT front bumper, Sylvania Cool Blue headlights, pcv filter,
Mods to be done very soon: addin PGT rear spindles to change to disc brakes, changin head to a PGT head thats port and polished w/3 angle vavle job, cam shaft reground by crower, dual valve springs, gonna bore out the block and add je pistons (custom make),
dont kno what else
anything else and ill add later
four year old thread is risen from the dead
89mx6dx f2
port an polished head,port an polished upper an lower intake,crower regrind cam,outlaw gaskets,new oem throttle body,hotshot header,9tp5to1 wisco pistons,msd 6a an tach adapter,msd 8.5 wires,hks cone,hks cat back,act 3stage race clutch,turbo trans,jet computer,cusom 1inch throttle body adapter,run 15.92 at 88mph all motor
1992 Mazda MX6 DX
Cone Filter
S13 Headlights
Capella Grill
Bosch spark plugs
NGK plug wires
Performance Probe Light Weight Pulley
Pioneer Speakers all around
Alpine Head Unit
Street Glow interior Neons
2.25 inch cat back exhuast
Auto Gear Muffler
Probe Gt Rear Sway bar
Mazdaman92 Custom Ground Wire kit
Soon to come:
Blaster 2 Coil
Custom STS
Probe GT front sway bar
Tokico Blues
Eibach Pro kit
ACT Clutch
Fidanza Flywheel
For now :D
Oh, my oh so modded six
Magnaflow XL performance muffler
Kenwood 12" sub in a homemade sealed box
Rockford P250 amp
Sony 6.5's in the back
I have an autometer boost gauge and Joe P MBC, soon to be installed after I get my cv joint issue resolved.
91 mx6 gt
front mount radiator
upgraded coolants hoses
aftermarket intake hoses
shocks
pegs........
Check the Sig
1989 Ford Probe GT
~EXTERIOR~
tinted sidemarker lenses
white ford emblem in front
white ford emblem in back
fog light mod
red LED tails
white LED rear plate lights
white LED reverse lights
white LED front turnsignals
yellow LED rear tursignals
TINTED tail lenses
hydraulic hood lifts
reflective thin black stripe across OEM spoiler
red bulbs in the rear sidemarkers for that darker effect
SILVERSTAR headlights
SILVERSTAR foglights
amber bulbs in the front sidemarkers for that darker effect
custom made center caps for the wheels "reflecive"
removed steel plate in the bumper (front)
removed plastic plate mounting area (front)
smaller re-mounted foglight housings
"reflective" side stripe around car
~INTERIOR~
white "halo" gauges
dual a-pillar pod
GReddy Profec B spec 2 EBC
LED courtesy lights
pilot steering wheel
aftermarket black leather shift boot
annodized red radio trim "reflective"
autometer phantom vac/boost gauge with white LED light
autometer phantom A/F gauge
CF ebrake cover
red ebrake boot
blue audio sensitive neon in center vents
red LED center LCD display
"custom""reflective" black interior conversion
"custom" red fabric within the panels along the doors and rear hatch area
polyfilled rear speaker areas(between the exterior skin and the interior framing)
soundproofed hatch area and filled spare tire well
~SUSPENSION and .I.C.E.~
front and rear strut bars
2nd GEN probe GT springs
EAS (electronically adjustable suspension)
gloss BLACK 16" FD3S wheels (YES the 13.8lbers)
slotted rotors
gloss RED calipers
kumho ecsta supra 225-50-16 tires
custom made Lower Tie Bar
longer ARP hardened wheel studs
7/16ths front spacers
7/8ths rear spacers
kenwood deck
5 1/4" Sony 3 way door speakers
(1) MEMPHIS AUDIO 12" DVC sub
"custom" ported enclosure (3cu. ft.)
1.5 farad digital capacitor
"custom" mono class d amplifier(polished)
custom made silver braided RCA's
silverbraid 4gauge power and ground wiring
silverbraid remote turn on lead
Monster Cable OFC "twist" 12 gauge speaker wire
SummitRacing digital voltmeter mounted underneath glove box
custom gauge pod for the voltmeter
Escort Passport X50 (red lighting)
MTX component tweets in the seat belt pillars
Kenwood 3way 6x9's in the rear passenger panels
24VDC fan wired on a toggle (for the amplifier)
~MOTOR~
F2T mazda SOHC intercooled turbo motor,
breather relocate,
cone filter,
custom intake heatshield,
gunmetal VC and IM and other things here and there,
2.5" catback exhaust,
no muffler (turndown),
NGK iridium IX's gapped @ .032mm,
ACCELL SS wires with MSD Pro-Race boots,
MSD blaster II coil with 12gauge OFC twist wiring,
engine ground kit,
HKS SSQV,
TB butterfly mod,
injecttech chip,
red silicone hosing here and there,
ram air induction,
full 2" IC hardpipe with 2 1/8" intake,
"custom" silicone TB and VAF elbows,
Platinum battery terminals,
Mr.Speed testpipe,
polyurethane trans mounts,
polyurethane motor mounts,
custom red resevoir covers (fabric),
custom made intercooler sprayer,
it can be seen in my sig;)
xbladr said:
Check the Sig
that's also bigger than the 5 line limit ;)
my mods...
tbird hybrid
jb weld and red silicone holding the IC together until new one appears in the mail!
haha I am trying but its tuff to get it to 5 lines... all set now :)
mods huh?
FE-DOHC turbo (FE3 came stock with the car, turbo didn't)
front mounted intercooler
programmable ECU
  • MAP controlled,
  • MAF sensor removed
compression ratio reduction
body reinforcements
lowering kit
burglar alarm
keyless entry
14" steering wheel
DIY pedal pads
trailer hitch ;)
90 GD1022
Coilovers
2.5inch exhaust cat back
De Cat
K&N Panel
Cold Air Intake
Turbosmart BOV Type 2 Vee Port
Turbosmart InCabin Boost Controller
coming soon - fmic
1988 Red Mx6 GT:
MOD LIST
Suspenssion and handling:
-Front Vibrant strut tower bar
-Rear factory strut tower bar (91 gt)
-Front and Rear addco sway bars w/urathane bushing and link kits
-Custom rear alluminum stabalizer bar
-Tokico struts
-Eibach pro spring kit
-New barrings and stut mounts front and rear
-Longer wheel studs with 1/3" wheel spacers
-Manual rack and pinion unit
-Moog ball joints and outer tie rods
-New disks and pads all round, new rear calipers and hand brake cables
Interior:
-Auto meter ultra light series, boost/vac gauge, pyrometer, oil pressure and air fuel ratio gauge.
-Innovate motorsports wideband O2 units, LM-1, LC-1 and X-D16 gauge
-Grant GT steering wheel
-Blue piaa interior bulbs
-Shift knob, shift boot, hand brake handle, car mats, pedal covers, seat covers (modified to fit) (all blue sport style)
-rear strut tower bar painted metalic blue
-blue fire extinguisher
-blue interior swap (so far, front seats, dash, door panels)
-Sony cd player
-Kenwood front speakers and shakker rears, (amps and kicker removed)
-Cleaned , inspected and retaped wire harness (1988 626 GT)
-Lane Changer miror attachement
-(dial tack with inteliglow needle set and blue bulbs, not installed yet)
-door buzers removed
Exterior visual improvements:
-None
Except
-American Racing rims
-Ugly hood scoop w/Carnage logo
-Hood Bra and sunroof viser (came with car)
-PIAA head lights
-Blue Runing lights
Drive-train:
-Rebuilt transmission w/ new shift forks
-Fidanza lightweight flywheel
-Bully Stage 4 Racing Clutch
-Tokico Master cylender and slave (clutch w/new mazda lines)
-Phantom Grip LSD with welded diff pin
-CV-tech 800hpr CV-Joints and matching cut hubbs
-Pace Setter short shift
-Polie-Urathane motor mounts
ENGINE BAY:
Visual & Practical:
-Hood lifts
-Cleaned, inspected, restored and taped red all wire harnesses
-all egine parts, brakets mounts, transmission... cleaned and painted
-Red grounding harness
-Stickers (decals under the hood)
-Red urathane vaccum hoses
-Red high temp heater core coolant lines
-All nuts, bolts , sensors, firewall brakets cleaned
-Painted, cleaned... Cruise unit, wiper motor, starter , (new brake master, not installed yet )
-red billet battery bracket
-polished stut tower bar
Permenant Engine Bay Mods:
-Stainless 3" exaust from turbo back, DEI exaust wrapped
-2 Dynomax resonators
-high flow Car Sound catalitic converter
-Mangnaflow muffler with tip welded twards the ground
-Intercooler sprayer runing on vaccum actuator (Larken Automation Original)
-cold air intake w/ insulated box, ram style air inlet in the fender and hood scoop
-3" aluminum rad
-Front mount high CFM pusher fan
-90 gt Dynamic chamber cooler, (ice water cooled)
-Relocated oil pressure switch and oil gauge on braded line to the fire wall
-MSD Blaster coil
-MSD 6AL Ingnition system
-MSD Timing control unit w/dial
-MSD Tach adapter
-Unorthodox Under drive pully
-91 gt injector plug swap on harness
-2.6l fuel filter
-Drycell Battery w/gold plated conectors
-Ported&Polished air flow meter
-HKS Super Sequential Blow Off Valve
-5TH injector with bung and VW 450cc injector (need duty cycle controler, soon to come)
-2 US windshield sprayer tanks 2litters each mounted under bumber for sprayer and intake cooler
"T-Bird" Engine
-1988 626 GT block w/123 000 milles
-new rear main, alternator and all gaskets
-ported & polished exaust manifold, turbo housing and O2 houding,
-DEI exaust wrapped manifold turbo and O2 housing
-Stage 1 Ported & Polished head, valves lapped and head shaved, Valve spring spacers
-custom ported and polished Throtle Body with 2 large butterfly flaps
-Stage 2 ported Dynamic Chamber, intake manifold with gaskets mached
-Outlaw engeneering thermo gaskets
-91 injectors
-Taylor 8mm wires (red)
-T-bird turbo upgrade (seaching for a new one)
-Turbo Smart manual boost controler
-Stage 1 street clutch w/turned flywheel
Mitsu 16g Engine
-1988 626 GT block w 190 000 km
-New mazda Rings, main and rod Barrings, block honed and decked, more elaborate painting of block and brakets
-New Water pump, Oil pump, Alternator
-New gaskest (complete)
-ARP head studds
-91 injectors
-Stage 2 Ported and Polished head, shaved with spring spacers and lapped valves
-Tial 38mm external waste gate
-Custom stainless manifold
-Mitsubishi BIG 16G TD05H turbo
-Polished Valve Cover
-Polished Turbo Housing
0.040 Over Block:
-Back at the machine shop
Other:
-Zombie chip
-Freeway and stock horns
MORE TO COME
1990 non turbo MX6
Custom metal intake with 3" k&n filter
ngk plugs abd wires
2.75" cat back Exhaust with dual 3' carbon fiber tip mufler
pioner head unit
bouston ecoustic speakers
2 12" explode subs with exlode amp
hopeful if i can get my engine fixed turbo convertion and body kit if i can find some one to sell me one
1988 Mazda Capella C2 GTR
Mods:
Momo 4-spoke leather wheel (factory diameter, dated 1992)
Skull shift-knob (factory was worn out)
Aluminium pedal covers (factory was worn out also)
FOHA bodykit
2.25" exhaust, no cat
Blaupunkt 4" front speakers in stock location
Pioneer 3-way 6.5" rear speakers in stock location
Pioneer DEH-P6450MP headunit
No mods to the FE-DOHC yet, but it's good as-is for now. Goin' supercharged in the near future... :)
Heh. I feel my car is puny next to these, but I'll go ahead anyways:
1988 MX-6 GT list:
  • Custom exhaust (pulled off a junkyard 1st gen) with a pretty big fart cannon (hey, it was damn near free and will do for now!)
  • Ractive cone filter with (fake carbon fiber) heat shield
  • Cracked TB boot
  • Hole in exhaust manifold
...and that's about it!
..I'm sad.
Engine I'm building for my B2200:
Bottom end:
Releasing core sand from block
Torque Plate honed
Crank counterweights aerofoiled
Micropolished crank
Cap girdle
"Other" crank modifications :)
Custom made high compression pistons
Beam polished rods
Baffled oil pan
Possably coated pistons
Fidanza aluminum flywheel
Keeping stock truck harmonic ballancer
Ballanced rotational assembly
Top End:
12-valve head
Hand made manifold
CC'd chambers, possably coated
Port work
Valve work, possably with coatings
Custom grind cam, also might be coated
J-Spec truck manifold or hand made manifold
Fuel and Ignition:
Megasquirt controlled
E85 Flex Fuel compatable
EDIS ignition
Low resistance coil wires
I'm sure someone will bash me for the coatings but I should be able to do most of it through ties at work and Calico is about 30 min away. I also want to get rid of the HLA's and replace them with solid lash adjustors if there are any that easily interchange. Roller cam followers would be nice, I might have an interchange possability on those that would reqire bushing to be press fit into the rocker body.
I also need flow numbers of a virgin head from .050" lift all the way up to max if anybody has them. Might be able to finagle using the flow bench at work if not. Havn't looked into valve possabilities yet and part of that will depend on flow numbers.
Who is running aluminum flywheels? I've had one to install for about 5 years now but never have because I was afraid it would be too hard to drive. Can anybody give me any input on how streetable they are? My truck will probably weight about 2,200 lbs or less by the time I'm done.
21 - 40 of 77 Posts
