Suspension, suspension, suspension.
I do run front and rear strut bars and trailing bars on all my F2T's but they don't make much difference.
Performance struts and coil springs and giant solid swaybars with monster link kits make the cars night and day.
They are pretty damn smooth and stable at 5th gear redline aside from the engine revving above 6000rpm.
How is 256km/h fast?
Did you know right now the earth is spinning at 1000mph
Did you know it's traveling around the sun at 67 000mph
Did you know our solar system is spinning around our galaxy at 490 000mph
Our galaxy and those surrounding it is hurtling through space at 2 237 000mph
And everything in space is moving towards the Cosmic microwave Background Radiation (CBR) at 872 405mph
So right now you are traveling at 3 667 405mph and can't even feel it.
Does 159mph still sound fast to you, besides I only travel at that speed against the earths rotation so while everyone else is going 3 667 405mph I am only going 3 667 246 mph but I would feel much safer if I could get it down to 3 667 216 mph (189mph top speed)
Once I ran out of 225/50 r16 tires street tires and threw on 205/50 r15 tires and rims. the 16" have a diameter of 24.9" (78.1" circumference) the 15" have 23.1" diameter (72.4" diameter), because the wheels are fixed rate with the diff (except when one wheel is spinning or the car is turning) running the 15" wheels is just like putting a shorter final drive in the diff, the car was no faster, just had to shift more cause all the gears where shorter. 238km/h was the top speed on 23.1" tires, race a car for 55km (Casselman to Ottawa) bouncing off the rev limiter in 5th the hole time, wishing I had bought another set of 225/50r16.
I hear what you are saying about acceleration vs top speed but you have an F2 block, it sucks for 1/4mile times, it drinks a lot of gas, makes lots of torque too early... But unlike all the square bore and stoke 2.0l sewing machines out there (86X86) the F2 gets faster the more you load the engine, the F2T with enough power will accelerate fastest in 5th gear. So when I'm about to race someone and he lets his passengers out for the race (so his car is lighter) I let them get in my car with my passengers for the race because it doesn't make as much difference with the F2T.
I powder coated some 16" MZU rims (heaviest 16" rim I have ever seen for a car) and put them on my 89GT mx6 (took off the much lighter protege 16" inch rims). After years of whatching people chase lighter rims and reading their posts... I was concerned they where so heavy they would make the car slower, but it was faster so I kept running them.
Besides you can't accelerate up to speed quicker with the wheels are spinning. The automatic F2T, no one likes automatics but the F2T with auto transmission will be much faster on the 1/4mile, especially in 1st and 2nd gear. They are much taller gears so the auto doesn't spin as much and just goes while the 5speed redlines 1st spinning and you try grinding it into 2nd gear (syncros spinning too fast). The auto has 4 speed transmission the gear ratios are 1st 2.80:1 - 2nd 1.54:1 - 3rd 1:1 - 4th (OD) 0.70:1 and a final gear ratio of 3.70: 1
Speed per gear with 24.9" diameter tires:
1st @ 6250 RPM = 72Km/h
2nd @ 6250 RPM = 131Km/h
3rd @ 6250 RPM = 201Km/h
4th @ 6250 RPM = 288Km/h (pretty sure it won't go that fast).
If the F2T with 15psi factory turbo can launch and accelerate like an STI in 1st and 2nd on an automatic transmission with these tall gears, then my more powerful F2T's can handle taller 1st 2nd 3rd or a 3.711:1 final drive.
At 6250rpm with 3.711:1 final drive on a 5speed H box with 24.9" wheels
2nd number on 4.105:1 H final drive)
1- 62km/h ---56km
2- 113km/h---102km
3- 168km/h---152km
4- 217km/h---196km
5- 282km/h---255km
With the F2T I bet 1st and 2nd would spin less and 3rd 4th and 5th would accelerate faster.
Above 400ft lb torque on these cars I don't think it matters how tall the gears are or how many.
On my way to the drag track I came across a Mazda 3rd gen RX7, I thought this was going to be easy but to my surprise we seemed dead even, before the drag track the highway widens to double lanes and we both took off from 120kph, we where neck and neck until I put it in 5th and pulled ahead.
At the track the guy came over to my 89mx6 GT right away to ask why it's so fast (I was brooding because it wasn't fast enough), I was running a 2.5" exhaust, 100$ saab t3 45trim, chip and extra injectors (full suspension of course), he was shocked, he said he used to own one but never realized they could be that fast, he asked what gear did I use to pull away, I said 5th, he said he was in 4th and we where dead even and when he got to his peak power area in 4th I walked away. Then told me all about the Built LS6 V8 he put in the RX7 and the Nos set-up (he wasn't running nos on the street), his first run was 12.1 seconds without nos and he never ran nos that day because he didn't bring a helmet and if you break 12seconds you don't get to run again without a DOT approved helmet.
Get your car running, get your tuning right see what you can get out of that 43lb/m turbo (rated to flow enough with .86a/r T housing on a 2.5L to make 550bhp, why do you want a bigger turbo?) and get back to me about the H type transmission gear ratio or put some little 23.1" 15's on and tell me if you think it's faster. With the most tire I can stick under the car with 0 chance of rubbing I just feel the car goes 1st gear- 1second- rev limiter spinning- 2nd gear- 1..2.seconds- rev limiter spinning. or say "Redline" (take a quick breath) say "Redline" again = 6250 in 2nd.
About the toyota gearboxes and others there is a good thread hear :
Gearbox Question
Unfortunately the 4AGZD E51 and E58. the 1ZMFE E153 and E58
All these transmissions would be about 10km/h slower redline 2nd, 10km/h slower 3rd and 10 to 23km/h slower in 5th than the F2T H box.
Like I mentioned the F2T has a pretty tall gear set compared to most transmission, put one on an 8000rpm revving honda and you could use the minute hand on a watch to time the shifts. it would do 71km 1st, 131km 2nd, 195km 3rd, 251km 4th and 327 km 5th (if something with higher top speed pushed it).
You do have the instructions and torque specs for the ARP head studs and MLS gasket. Always torque head studs or bolts wet.
I will be honest it sounds like you followed a bunch of online recipes, Head studs, MLS gaskets, high comp pistons (have some don't use them, tried one run felpro instead, don't want them lower comp more boost makes more power).
Perhaps E85 will work well with your combination.
When searching for info online don't just look at the mods people do and all their advice during their build look for how long their build lasted, there seems to be a pattern of hardcore F2T and FE3 building members being online up to and a little after they get their car running and then they disappear, based on the fact they spent so much time on the forum before I don't think it's because they where too busy driving and enjoying their cars to share the results.
And I guaranty none of the project failures are because of the F blocks, they aren't snapping cranks and rods. But they blame the engine and not their lack of experience and skills and move to another engine and join an SRT4 or Talon forum and copy recipes on that forum.
The Shitty tuner blames the engine and moves on, I think the mazda F build should be moved to a better tuner and the shitty tuner should modify pedal bikes instead of cars.
Take your time, double check everything, learn to read spark plugs, get an EGT sensor (because of the high compression) and don't blow the engine and move on or I'll add you to the shitty tuner list.
If you do blow the engine it's no big deal, get another F2T run it with factory internals, make more power for less money and continue learning. Don't get attached to an engine or car get attached to a type of engine or a model of cars, engines blow up, cars get hit or crash, there is no such thing as bulletproof or indestructible, everything wears down. Every good engine builder in the world has blown engines bet the best have blown up the most because there is only one way to find the limit and next weakest point to upgrade.
Juanpac_tupac has impressed me most of almost all the 1st gen standalone users, never pushing the car beyond his tuning skills and progressively improving things.
I think the real problem is our sense of reality, I played grand turismo and read import tuning magazines, my first F2T build I started with the engine, bigger pistons, full rebuild... but go figure the guys at the machine shop knew even less than the Mazda engineers. I learned the hard way ($$$), all that stuff matters with N/A builds, turbo build you need tough parts, low compression, a set-up that flows and lots of boost and fuel.
I think that's the difference between a tuner and racer, a tuner bases his build on the engine a racer bases his build around the engine choosing a stout affordable easy to replace drop in block and all the work is done around it not in it.
I think tuners start their project disillusioned and are shocked and but hurt when the engine blows up.
The racer expects the engine or something to blow up but planed ahead and every day stuff survives is a win.
You have spent a lot of money on the block you plan to learn tuning on, that's kinda like wanting to learn to tattoo and doing you first one in the mirror on your face instead of a cheap piece of pig skin. So tattoo I mean tune carefully.
