1 - 18 of 18 Posts
need to find location of the engine number on the 2.5ltr quad cam v6 from 626.... thinking it might be 94 model
any help would be appreciated!
thanks BEN
You mean the number that identifies each particular engine (the serial number, so to speak)? If I remember correctly, it is located somewhere just below the distributor.
Discussion Starter #4
thats exactly wat i mean, cheers mate ill try looking there
It's actually down the back...
from the cambelt side (front), look down the left side between engine and firewall.. its stamped on a flat area on the block.
pretty hard to see by all accounts..
John
Sorry. Yes, I think you are right John. My memory must be failing. I did a search and found this:
"Just went down to look at the engine on my stand.. it's on the rear of the block toward the driver's side just above the oil pan."
Discussion Starter #7
i take it ill have to get under the car to see it then? as i couldnt see past the exhaust manifold.. but thanks guys
It's facing upwards, so you won't see it from below...
I did say it was pretty hard to see :)
John
Discussion Starter #9
i located a number at the very rear of block stamped just above where gearbox bolts.. would that be it?
its a total of 6 numbers... with a 7th number stamped underneath
i.e 105397
......5
Sorry, no... it's at the front (cambelt side)
Should start with KL
John
thats not a 2.5lt KL motor
its out of a 929.
thats a KLZE
yours is def out of a 929 like this
Discussion Starter #13
wat size is my motor then.... i was told when buying it that its a 2.5ltr quad cam V6, when ever i ring up for parts they tell me its from a 626... can someone tell me exactly wat my motor is.
my intake is smaller then the one shown tho....
Well, it's certainly not a K series...
2.5 L J5 V6
3.0 L (2954 cc) JE V6, SOHC, 160 hp (118 kW)/180 N·m (245 N·m)
3.0 L (2954 cc) JE-ZE V6, DOHC, 205 hp (151 kW)/200 N·m (272 N·m)
my guess being that it's DOHC is the 3.0 JE-ZE.. but the 2.5 may also be a DOHC engine..
John
Discussion Starter #15
i know i have 126.9hp at my rear wheels... and i can beat turbo VL's hahaha
its definatly the JE model i found my engine number, which the pits told me was the manifold part number.... stupid pits guy
199 Mazda 626 engine number
Please I need to know the engine number of my car Mazada 626
Model: GF3m EA8
Chasis No: JMZGW19S201121906
MOTOR: FS 477668
FARBE: 4F GE4
AN-HD 10343
thanks Rose
1 - 18 of 18 Posts
