how do you get these out?
Has anyone had to do this before...
Over the weekend some jack offs broke into the ride and stole my system....
What do you mean how do you get them out? I'm assuming they poped your locks in order to gain access to your car correct? if so, then what exactly do you need to do with the lock cylinders? if you need to gain access to them, you need to remove the inside panel and plastic cover and simply reach inside and you'll be able to feel them.
pasenger side i can get to. no problem but the driver side is still in place but the bent up the inner workings of the lock so i ned to get the cylinder out to have the locksmith re- key it for me...
The only way to gain access to the cylinder in order to remove it is from the inside. You mean you can't get to the inside or you can't find how to remove it?
