but how much weight will it reduce? do you enjoy low end torque?
ey?lightweight flywheel = no low end torque, but you will feel more power up top in the butt dyno
ey?? .You lose some low end torque
How accurate is your butt dyno are is that too sensitive? :muhaha:lightweight flywheel = no low end torque, but you will feel more power up top in the butt dyno![]()
It is hard to understand things that are not true.but I don't understand how that would actually reduce the torque.
I can't find the link, but it only has to do with launching. When you have a heavy clutch and launch, the extra rotational mass provides an extra kick in the teeth to get the drivetrain in motion from a static position (provided that the clutch doesn't slip). Where as with the lightweight flywheel doesn't have the same ability.It is hard to understand things that are not true.
It's a good thing you have your entire [fizzle]ing car as a flywheel, a few kg of rotational inertia don't make a lick of difference to torque or power delivered anywhere in the rpm band. Listen to STW if you don't like me, he's an actual engineer, not a back yard hack like me ;-)
Fred.
