our cars don't have a Maf. We run a Vacuum air meter... plug type. Simply put we have a domed plunger that sits inline with out intake when air passes over it it pushs the plunger backward against a spring to make room over its outside diameter. The farther back it goes the bigger the hole it makes and the larger a reading it sends to the computer. This is effective but very restictive. A maf has a small venturi mounted in the intake and takes measurements off the air flowing across it, Open element, nonrestrictive. A conversion would open our cars to faster throttle and help greatly in turbo applications. The problem swapping the two comes in the interpretive software mazda used. The stock ecu software is complicated and hard to adapt. You know what they say if it ain't broke, leave it the fu c alone.
