can anyone tell me how to properly replace the marker light bulbs? of the 4 on the car, i have one that works... there's no obvious way of removing the lenses, and i don't want to go at them with a screwdriver (fear of scratching my already dying paint :( ), unless i absolutely have to.
thanks!
you can take a screw driver and pop them out, just use a cloth to protect the paint, or you can remove part of the wheel well and try to release the clips with your hand from behind the lense.
either way, they're just held in by clips and will pop out.
by the way what size bulbs are in there? i haven't looked.
Lie on your back, stick your head under the front bumper (just in front of the front tire), and look up. You'll see how the marker is held in place. To remove the lense, squeeze the clips and push toward the outside of the bumper.
To replace the bulb, there's no need to remove the marker. Just twist the bulb assembly and pull it out. 30second job, no harm done to anything except for maybe some dirt on your hands.
