Hi, i will be putting my six on the road soon, jus wondering what tunes up i should do, please list everything that would be good to change, thanx
well from your post, i'm guessing you have a brand new six with no miles on it, you can actually drive it without any maintanence.
sorry but that is a really vague post.
some things i've had to do on my six just because of age are , both axles (torn cv boot), transaxle seals, ball joints (torn boot), shifter bushings, exhaust manifold studs (other ones broke off after i fixed some), timing belt, tensioner, idlers, water pump, crank and cam seals, hla's cleaned out, tires, brakes (pads/rotors)i can go on and on, but maybe some history on the cars previous maintinance and mileage ect may help us diagnose a bit better.
First things I do with a new (used) car is change the oil, oil filter, air filter, radiator fluid, and spark plugs. After that, it depends on what the car needs.
