um... 300cc isn't much. that's about what the milennia S injectors run. depending on how much enrichment you have, 90% duty cycle doesn't sound all that far off for 8psi.
also - where you source your gauge's vac/boost supply, vs your MS source from can make a difference.. pre IC can be 1-2 psi high.. too thin a source can read a bit low... etc.
