I have an Auto 88 Mazda 626 Capella. Recently the 4WS light came on and now it won't go off. Can sumone pls help.
You should try the 4ws section on here instead, not everyone reads the 626 forum alot, unfortunately.
I also own a 626 4ws btw, but its an FE3 5spd :)
It is indicating a fault with the 4WS system (or associated component)
The best thing to do would be to pull the fault code from the ECU, this will pinpoint the problem..
One of the most common causes is the rear angle sensor..
John
