Hey people,
First let me say this is an awesome website you guys have here! So much information, so many knowledgable people. I can see me getting nothing done at work for the next 6 months!
I have done a lot of searching around the web, and searching through this website, however finding a few specific pieces of information is proving difficult (or perhaps my Google skills aren't as good as I thought...).
First off:
I have a RWD 1986 Mazda HB Cosmo (Japanese domestic version of a Aussy/NZ/Euro 929).
It is the series-2 model, with a FE 8-valve Multi-point injected motor, 5-speed manual, and a LSD from the rotary powered model.
I have modified the existing FE only mildy, but am thinking upgrading to a FE DOHC is the most logical next step as turbocharging is going to introduce alot more headaches (mainly with the ignition and fuel systems).
My current plan is to purchase a 626/MX-6 FE DOHC longblock (plentiful in NZ), and use my current gearbox, injection system, airflow meter, and ignition system. I am aware some tuning will be required! I also plan to weld the lower part of the FE DOHC intake mainfold to the upper existing FE manifold.
My questions are as follows:
1) Does the Mazda FE DOHC have the required bolt holes to mount in a North/South RWD configuration? Or am I going to have to purchase a Kia Sportage block and transfer everything over?
2) Will my existing flywheel/bellhousing bolt straight on to the rear of the motor? From what I have read the Kia motor will not, but the Mazda FE DOHC will bolt up to a F2 drivetrain. Would I be correct to presume an FE and F2 have the same bolt patterns?
3) Does the Mazda FE DOHC have a place to mount the distributor in a RWD configuration like the Kia Sportage FE DOHC?
Thanks in advance!
Aaron
First off:
Thanks in advance!
Aaron
