Status
Not open for further replies.
I have my AEM uego hooked up and working fine and now i want to wire it up with my megasquirt but the manual says you need a 5 volt source for the blue wire. What can i use as the 5 volt source?
go buy a multimeter, its all you need to figure out which wire has what voltage.
Blue is for datalogging. You dont need to hook it up to anything.
You need to run the white wire to the MS proper pin. Do you have a Plug n Play unit or Did you wire it up directly to the OEM ECU harness?
What year of car?
What model of UEGO?
thanks, yeah i figured out when i went back to check the manual that i had just miss interpreted the instructions :p, can delete this thread if you like
Status
