1 - 20 of 107 Posts
· Registered
'95 Hunter Green LS 5-Speed
Current pic for thread thumbnail:
Automotive parking light Car Sky Vehicle Cloud
Original post starts below:
Hi guys. Just picked up this beauty today:
'95 V6 5-speed, 103K.
First thing I did was to 86 the sunroof shield. Hate those things.
It has a misfire. No CEL, but it's OBD1 so I'm going to have to figure out how to jump the fuse block to see if it'll tell me anything.
Took it for a short spin around the neighborhood. It actually drives pretty well other than the misfire. Shift bushings are totally shot though. The V6 makes nice "big engine in a little car noises." A/C blows nice and cold.
Some cosmetic defects: Needs some PDR on the doors, and the driver's door panel insert is pulling away. One pea-sized hole in the driver's side outer bolster. A few scratches just below the passenger window. Headlights need polishing.
The car appears to have survived the early 2000s import tuner scene with its dignity mostly intact. The airbox and wheels are stock, as is the headunit. There IS a disconnected Kenwood amp in the trunk, though.
Overall, quite happy. Will keep you posted.
· Registered
Discussion Starter · #2 ·
Hey, thanks for approving my post!
So a little progress yesterday while I'm waiting for basic tuneup parts.
Haynes manual get:
Automotive parking light Vehicle Car Hood Tire
Removed the Kenwood KAC-606 amp and associated wiring from the trunk.
Rectangle Wood Font Material property Beige
Apparently it's worth a little money so I threw it up on the 'Bay. "Streetwires" underhood fuse and heavy-gauge wiring straight in the bin. Looked like a professional install, but...no. Going OEM.
On the way:
  • Fuel filter
  • Oil filter
  • Air filter
  • Cap & rotor
  • Trunk struts
  • Headlight polishing kit
  • Bronze shift bushing kit
  • NGK spark plugs
  • Battery terminals
Going to start with a basic tuneup and see where that gets me.
· Super Moderator
Welcome aboard, ya get the basics done, but know that the dizzy's in these things can die often. Being you're in the US, Autozone has life time warranties on them. So make sure if you do replace it, get it from there.
· Registered
Thanks very much! Looks like it's pretty dead around here, but that's OK. It's a shame most of the DIYs have dead image links, though. I could use a visual or two for some of the repairs I have in the pipeline!
· Registered
which ones?
Well, like these:
It's not a huge deal, though. Plenty of other resources out there to draw from and I'm pretty handy with a wrench.
· Registered
Going to guess the misfire is from oil leaking out of the rear valve cover. If there is oil on the spark plug boot that is the likely culprit. Congrats on the purchase and Good Luck!
Thanks! I'll give that a look. Spark plugs are one of the items on the list this weekend.
Parts are starting to trickle in. Wiper blades and trunklid struts in what little time I had to work on it this evening.
Vehicle Motor vehicle Automotive lighting Hood Car
Automotive lighting Hood Automotive tire Motor vehicle Automotive design
Tires were pretty low also, so I filled them up to 35 psi all around.
Don't want to open a can of worms, but I'm thinking Motorcraft 5W-30 semi-syn for the oil change this weekend. It's what our Mazda5's engine swims in and loves it.
· Registered
A little progress:
  • First bath. She cleaned up VERY nicely. Pics forthcoming.
  • First oil change. Super easy, Wix filter + 4.5 quarts 5W-30.
  • Pulled the spark plug boots to check. They're all dry as a bone.
  • Pulled the codes. We have: 16, 25, 29, 41 and 46. Seems to be pointing me in the direction of the EGR system and VRIS solenoids.
More parts going on tomorrow. Will report back.
· Registered
She has been christened; her name is Megumi.
Some post-bath shots:
Automotive parking light Wheel Tire Vehicle Automotive side marker light
Automotive parking light Wheel Tire Car Automotive side marker light
Vehicle Car Motor vehicle Speedometer Steering part
Car Vehicle Gear shift Motor vehicle Automotive design
She cleaned up SO well, and I'm not even done yet. Still can't believe what I deal I got.
Engine bay clean and replacement part installation slated for tomorrow. These came in also:
Font Auto part Metal Cylinder Titanium
Next weekend maybe.
In not-so-great news, here's what a sunroof shield does to the paint underneath:
Automotive lighting Motor vehicle Hood Automotive design Vehicle door
Hood Car Automotive lighting Motor vehicle Water
:mad::mad::mad:
I have some factory Mazda 5S touch-up paint, but still... Makes me angry at the previous owner(s).
· Registered
OK, so:
✅ Fuel filter replaced.
✅ Air filter replaced.
✅ Dist. cap & rotor replaced.
✅ Air tank-to-coolant reservoir neck repaired.
✅ Engine bay cleaned up.
✅ Two VRIS solenoids and a length of 4mm vacuum hose ordered.
Took a peek around the back of the intake manifold, and there's definitely some Mickey Mouse action going on back there. Going to get it all sorted.
I'll probably throw the smoke tester on the intake also (the adapter for my E46 should fit the snorkel) to check for any additional vacuum leaks.
· Registered
Haynes manual get:
On the way:
  • Fuel filter
  • Oil filter
  • Air filter
  • Cap & rotor
  • Trunk struts
  • NGK spark plugs
  • Battery terminals
I had this exact car only it was a 1994. I loved it. Had it for over 25 years. Totaled it in January due to black ice. Anyway, I once had a miss that was intermittent and chased it for months.
It turned out to be bad Magenor spark plug wires. Might want to consider replacing them. I replaced mine with NGKs and the miss never returned. Also, this car is very sensitive to battery ground connections. Make sure the battery ground is clean and in excellent condition. This car can do funny things if the ground is not good. Had a problem with the gauge cluster going completely dead intermittently (very infrequently). Chased this problem for over a year. Replacing the battery did not help. Replaced the negative (ground) cable from battery to body with heavy gauge wire and cleaned the connection and the problem disappeared forever. Cosmetically, I put RX7 wheels on mine with P225-50-ZR16 tires. Make the car look a lot more sporty. Good luck.
· Registered
Discussion Starter · #14 ·
Thanks guys! Good tips about the spark plug wires and grounds.
VRIS solenoids and vacuum hose were delivered today. A local you-pull-it yard has a couple of 626s and Millenias; going to visit this weekend and see if I can grab anything off those.
Anyone have a source for the driver's door cup/pull thing? Or a part number? Mine has disintegrated and I can't even find it on a parts diagram to be able to ask the dealership about (though likely NLA).
@jcpost62, do you have pics of yours with the RX-7 wheels? I'm very pro-OEM but tentatively open to a different look if all the stars align.
· Registered
Discussion Starter · #15 ·
Yep; here's our botched repair on the VRIS solenoids...
Wood Office equipment Gas Office supplies Machine
And here's the repair (actually, the replacement) done correctly:
Gas Camera accessory Machine Auto part Metal
Should (hopefully) take care of the VRIS solenoid error codes...
I had read horror stories online about how hard it was to access/remove the solenoids, but it turned out to be pretty easy. Going to get it buttoned up in the next day or two and see where we are.
· Registered
More eye candy from the Saturday photoshoot:
Wow, paint and especially clear coat looks really great. My 94 had pealing clear coat on roof and doors. Tennessee sun really hard on clear coat. I loved this car and would buy one again if I could find one. Good luck.
· Registered
Discussion Starter · #18 ·
Thanks! Pretty sure it was garaged most (or all?) of its life for the clear coat to have held up this well. As far as I can tell, it lived all of its life in the Memphis area before joining me here at the other end of the state in Chattanooga.
If you want her, let me know. There's a better than 50% chance Megumi will end up on Cars & Bids, if I can get her running well and polished up...
Evening scene:
✅ Low 70s
✅ Light breeze rustling the leaves
✅ Back end of the summer humidity
Perfection.
Automotive lighting Sky Building House Road surface
· Registered
Discussion Starter · #19 · (Edited)
Pretty productive couple of days.
✅ New pair of VRIS solenoids installed, w/4mm silicone tubing as needed.
Discovered the smoke tester adapter I made for my E46 fit Megumi's intake perfectly:
Automotive fuel system Automotive tire Automotive lighting Hood Flash photography
On to the smoke test today. Getting the machine warmed up and plugged in:
Hood Motor vehicle Automotive design Automotive air manifold Automotive exterior
Screwdriver is cracking open the throttle butterfly.
No leaks except for a few wisps around the rock-hard intake boot:
Automotive tire Motor vehicle Gas Automotive wheel system Auto part
Need to replace that piece anyway. But the good news is the rest of the intake is airtight.
Gave the bay another bath and reinstalled the airbox & battery:
Vehicle Hood Motor vehicle Car Automotive design
I have a new "V6 DOHC 24-Valve" sticker on order.
I re-cracked the stupid neck to the air tank as I was reinstalling the airbox. :mad: Guess I'll have to reglue it; those things are worth their weight in gold apparently.
So...she runs a lot better. I think she still has a slight misfire, but it's really hard to tell. Ample power and no threats to die at any time. I checked the codes, and we're down from 5 to 2:
25: FPR solenoid
29: EGR vent solenoid
Tomorrow I'm going to time the engine and see if that will help smooth out the engine even more. Can't hurt.
Oh, I raided a few Millennias and a 626 at the junkyard earlier and snagged some plastic bits and another pair of VRIS solenoids just in case the ones I bought didn't work.
Cloud Sky Tire Car Wheel
$11:
Automotive tire Font Wood Tire Metal
Bonus pic: Megumi and Indigo chilling together in the driveway.
Automotive parking light Wheel Automotive side marker light Car Vehicle
· Registered
Discussion Starter · #20 ·
More progress today. I was going to time the engine, but, well, that didn't happen.
I did replace the FPR solenoid with one from my junkyard trip yesterday; seems to have taken care of the code 25.
Motor vehicle Hood Automotive design Automotive tire Automotive exterior
Then I decided to replace the shifter bushings with the bronze set + hardware I got from Exile.
Removed the crossmember, then I undid the two bolts at the back of the cat, enough to push the rear section of the exhaust back so the cat would drop out of the way:
Automotive tire Hood Tire Automotive lighting Tread
Wheel Tire Motor vehicle Automotive tire Hood
Probably should've supported the cat rather than letting it dangle from the flex pipe, but oh well.
I temporarily bent down the front tongue of the heat shield below the shifter, and unbolted the arm without any drama:
Road surface Snake Asphalt Wood Scaled reptile
The bushings at the shifter were in good shape, actually, but the ones at the transmission end, were GONE. Like, nonexistent.
The Exile kit requires you to open up the holes in the shifter end of the arm a little bit:
Wood Drilling Table Wood stain Hardwood
They look like this when installed. Shifter end:
Wood Wood stain Camera accessory Hardwood Cameras & optics
Automotive exterior Bumper Auto part Trunk Gas
^You can see the heat shield tongue bent down. Bent this back into place during reassembly.
Trans end:
Gas Wood Electric blue Nut Household hardware
Automotive tire Motor vehicle Auto part Gas Rim
Shifts like new now. No slop at all; it feels absolutely perfect.
I drove her on a 10-mile errand round trip, and the slight misfire is still there. Pulled the codes when I got home, and we have 16 and 29. So something's definitely up with the EGR system. I got a good look at everything at the back of the engine when I was under there earlier, so I feel pretty confident to drop the crossmember and exhaust and replace what needs replacing. Those vacuum solenoids are a dime a dozen at the junkyard, too... Stay tuned.
1 - 20 of 107 Posts
