I don't get it. The car started to "hiccup" a few days ago. I am assuming that it is missing. It seems to only do it when the car is moving. On my way home from NY about an hour ago it just stalled! I had the cruse control set at 60, and the thing just stopped running. I don't know if the engine stopped spinning completely before I put it in neutral or not. I remember that the check engine light did go on, or flash. I turned the key to the off position and drove to the side of the road. Everything seemed to go so fast that it all seems blurry now. I got out and looked at everything; everything seemed to be fine. I started it up and it ran like nothing was wrong. The rest of the way home it only "hiccupped" once. Does anyone have a clue to what this maybe? Igniter? Fuel filer (it has 60k on it)? Spark plugs have about 7k, wires 4k on them.
[Edited by kennymx6 on 01-17-2001 at 01:52 AM]
Maybe same problem as mine!!
I got a 93 MX6 V6. My problem is the car running at 70mph and stalled, after about 1 or 2 minites, can run it agin. Now the ignitor is totally gone, i need to spend 380+- to replace it. I just known the 93 & 94 MX6 V6 got the problem of the ignitor. the transistor of the ignitor got problem, after that, there have redesigned a more powerful one. So u better check the ignition distributer.
Oops. I forgot to post what I found out. It was a few things. The connector on the coil where the igniter wire attached was corroded. Second, my spark plug wires are bad.
Dude, that's gonna cause issues!
Shout louder, Panther, kennymx6 hasn't logged on in 2½ years.:D
