1 - 9 of 9 Posts
OK I have a question for those of you that have installed a MSD Blaster SS coil. Where did you put it and how hot does it get? I was planning on using the factory mount but my VAF is in the way on the one side and the other side is on the fuel filter and fuel lines.
I made a simple plate to mount it to that used two of the bolt holes on the coil side of the strut tower. To make it easy, take the VAF out of the way and look at what you have to work with there.
theres a vacuum canister under the intake manifold. if you have a spare one of those, they work AWESOME for holding the blaster coil in the stock location. i was the 1st to do it, and have had quite a few others try it, and like it quite a bit.
please dont just let ur fuel filter flop around, and put the blaster coil there. thats just stupid, unsafe, and ghetto
I also used a plate for mine.
Minus, I put mine where the stock coil was.
And have it standing upright.
1 - 9 of 9 Posts
