1 - 8 of 8 Posts
hey guyz i juz drop a kl-de in my mx-3 n when i start the car up its not idle'n right ,sometimes the motor sounds like it misfire or stutter and sometimes it idles fine then the idle will drop lower for a lil bit then come back up...me and my friend went back n check every vacuum lines n sensor and everything seems to be rite...so does anyone know whats wrong ?
The KL57 is from a 94 MX-6, so was right in that car..
Does the car run ok other than the idle?
What else was fitted from the donor car besides engine and ecu?
John
It sounds electrical, rather than fuel..
Check ignition timing, rotor arm, distributor cap, leads and plugs..
I'll presume the engine was running fine before fitting it..
John
Quick question TK2269, the vaf you say you have, did it come with the engine ? is it the ZE vaf ? if so i dont think the KL57 ECU you have is a ZE one, and the ZE vaf does not work with the DE ecu's. Let us know which VAF you have.
Oddy.
1 - 8 of 8 Posts
