I am curious, will a probe tranny fit in my mx6, i have the 4 cylinder automatic, also is it really that hard to make it a manual transmission if i find one? Will the v6 tranny fit on the 4 cylinder block? probably not but i am interested in the auto, to manual trans swap b/c i hate the auto. thanks guys my car is a 1994
It is possible to do the auto to manual conversion, but you will need a few more things that just the tranny. I do know that you will need to replace the drive shafts as they are a different length. There are otehr things that need to be done but I can't think of them at the moment. Amazingly enough the MTX is the same for both the I4 and the V6 with the only difference being the gearing in 3-5 gears. You should be able to use the tranny out of a Probe no problem, again the only differences being the gearing adn final drive ratio.
