1 - 1 of 1 Posts
Hi All,
I thought I'd share this image which is the "homemade" gasket for my MX V6 distributor cap (1994).
A "mechanic" put silicon to "repair" the original broken gasket, unfortunately this blocked the drain at the bottom, and may have contributed to the ignition coil failing.
I looked on the inter-web for a gasket and found one in the U.S. but I needed one ASAP, so I made this template.
https://drive.google.com/file/d/0B6eHpIwkKKDAOHNKcFFfWmc3SDQ/view?usp=sharing
I have attached it as well. Download it, open it with MS Paint, goto "File" => "Print" => "Page setup", and switch the settings to "adjust to: 100%" ...then print it, stick it to your favourite gasket material that is about 2-3mm (0.12 inch) thick.
I hope this helps someone! :smile2:
Image:
1 - 1 of 1 Posts
