1 - 15 of 15 Posts
Its been years i have logged into the forum, Well i picked up a project car , 89 MX6GT, an the whole idea of the project is to spend as little as i can to make 500hp, but i can use any of my old parts laying in the garage shelf.
the car came in as a bucket, crack dash, not running, missing front bumper etc
here is the way i got the car
so tthe first thing i did is pull the motor out the car to see what it will take.
pulled the motor apart and start the built, installed wiseco pistons, dual valve springs, ported head, larger valves, bigger clutch, bigger injectors, bigger 450lph pump, meth injection etc
Discussion Starter #5
5th injector setup
13285
Discussion Starter #7
here is he car
Discussion Starter #10
I got some front and rear maroon door panels if you need any. Been sitting in my shed for years
i want to convert the window to manual , is the door you have have manual windows on it? by the way, what do you mean front and rear? mx6 only comes with 2 front doors
They’re power windows panels and by rear I meant the rear panels not rear door panels
I noticed you have very large ports welded onto the valve cover. Is that for extra crank case ventilation? I'm currently exceeding the venting capacity of my filters and tired of the oil on the valve cover. I should probably look into a catch can set up. I was thinking of running it through the stock ports but it looks like your top vent is for an oil catch can. Just confirming the extra port is indeed for venting and not anything else
Discussion Starter #14
I dont use catch can, its a crankcase ventilation port, The stock port is too small, I have 5 vents
Discussion Starter #15
what do you want for the Door panel, left and right?
1 - 15 of 15 Posts
