1 - 8 of 8 Posts
you know the old saying, when it rains, it pours....my 6 is starting to show its full 10 years and its driving me nuts...first of all, at exactly 3000 rpm, i hear this grinding noise, not too loud but annoying as hell, coming from the engine bay, it disappears at 3100 rpm. i don't know if its the flywheel or what but like i said, its annoying. secondly, on a cold day, as i move off in 1st gear, there's this high pitched squeal while my clutch is engaged. once again, the noise disappears when i let off the clutch. finally, i think i've got a loose wheel bearing because i can hear squeaking from my wheels when i'm driving. i have some money but i don't have the time right now to work on it and i don't want to send it to a shop where they will rip me off on labor. maybe i'll do it over spring break, which is next week, so any help would be greatly appreciated. thanks!
The wierd grinding noise may just be a loose exauhst shield...like the one on the cat. Mine vibrates and makes a metallic type noise around 3000 rpm sometimes
It may not be a loose bearing, but merely one that needs to be greased, I am not sure of the procedure for the MX-6 yet cause i haven't got my shop manual in, but it's usually pretty easy-messy-but easy......
The high pitched squeal when the clutch is engaged sounds like it would be the throwout bearing. Clutch jobs aren't too hard, but, if you have to have a mechanic do it, they aren't cheap either.
It'll probably just make noise and you won't have any problems with it. Not sure about the other problems.
Squealing while driving- squeal tabs on brakes? Check'em
Wheel bearings are sealed-not greaseable- usually don't squeal.
I agree with the throw out(release) bearing for the clutch noise. High possibility there.
Definitely check those heat sheilds. Bad about coming loose and making lots of racket!
hey all,
thanks for all the advice, i'm probably going to have a look at it over spring break so wish me luck!
blackgt, only rear wheel drive cars have greaseable front wheel bearings.
I replaced one of the front wheel bearings in my car, (it was a bitch, by the way), and when that bearing was bad, that was more of a rubbing sound, not a squeak.
I agree with mkb, if your wheels squeak while driving (this goes for pretty much any car nowadays), it's probably your worn brake pads.
Magik8, some front wheel drive cars, like my old escort have greasable front bearings, i was wrong with the mx-6, but there are some that do have them.
1 - 8 of 8 Posts
