Hi,
I am from South Africa and I have a mazda rustler, which is basically a Mazda 323 pickup.
I have added the following main mods to it:
- FE3, engine
- Toyota E153 gearbox
- Aftermarket ECU for fuel
- MSD 6BTM for timing
- Hybrid Turbo
- 16 inch MOMO Alloy wheels
Here are some pics:
After lending my ears out to a "specialist" I initially installed a T3/T4 60-1 Hybrid turbo, which was extremely laggy (making full boost at 6000rpm), but made 385 wheel hp with 1.6 bar boost on a reputable Dyno.
After learning on how to plot compressor maps, I built my own
Hybrid turbo and recently went to the Dyno to see the resluts. I decided to only boost 0.8 bar with 95 unleaded pump fuel, as a feeler. The result was 302 wheel hp.
The engine bay had some heat soak after all the tuning and due to pressed for time, the final run for the print-out resulted in 4hp less.
Will turn up the boost for the next visit to the Dyno.
What do you guys think of my results?
For Info: Another vehicle with a FE3 T3/T4 Hybrid Turbo conversion did a power run just before my Dyno Tune and made 312 wheel hp on 1.2 bar boost.
Sweet ride. Thats what the Ford ranger should have came with, in the states at least :)
