just bought new factory headlights and the corners next to them
had my autobody guy put on the headlights, however the side lamps "corners" just came in (late )and my car is home now from the shop
So my auto body guy told me to just take out that phillips screw that holds the corner lamp down and then pry the corner loose and then it would just "pull off"
anyway, now my auto guy is on his honeymoon for the next week and you guessed it
I CANT DO IT!!!
I took off the screw just fine and can pry loose the lamp with a flat head screwdriver... MY PROBLEM IS I cant get the corner lamp to pull off , to pull out !!! It doesnt want to come straight out - seems to give resistence and I dont want to break anything
Can somebody please help me out here
thanks a lot in advance
if you refer to your owners manual, i think it gives step-by-step instructions on how to remove/replace that corner lense... if not, lemme know I'll copy mine on for you
thanks
I got the old ones off and new ones on
just a little tricky pulling them off ...
