When I bought my MX-6 a month ago the power antenna was broken, so I ordered one of those replacements off of e-bay. It hasn't arrived yet but I looked in the trunk at the panel where the power antenna is attached and am not really sure how I'm supposed to remove the antenna. Does anyone know how?
Pull the carpet away from the passenger side, inside of the trunk. You will see the power antenna assembly there. Take off the keeper ring on the outside by unscrewing it. Then disconnect the multi-wire connector and antenna wire on the power antenna unit. Then you have to remove one bolt that mounts it to the frame, then pull her out. This really isn't step by step, but those are the things you have to do to get her free. Very easy though.
