need help speedometer don't work
88 Views 2 Replies 2 Participants Last post by  mazdaboyz
hey guys and girls i just bought a 1994 mazda mx-6 mystere LS v6 2.5 L the car is standard and they guy i bought it from said he replace the clutch and ever since then the speedometer hasnt worked so i need to know where i should begin looking i replaced all the fuses that run the cluster everything works execept the speedometer the tac works fine any help would do me good thanks in advance :confused::confused:
Hi and welcome ..
the speedometer is electric, and plugs into the speedo sensor of which is located to the top/rear of the gearbox, below the throttle body area. Will look like a short stick pointing up with a single bolt holding it in place. Ensure its plugged in, as its my guess after the cluth replacement, it was not reconnected.
Oddy.
thanks i will take a look tomarrow :tup::tup::tup::tup:
