· Registered
most of the guys in the audio section are 2g's. I need a wiring diagram of the audio system...mainly the sub. I wanna see what it could put out. Also if anybody has any advice i'd love the help.
· Premium Member
All you need to do to hook up the sub is take the blue wire with the yellow stripe located in the factory wiring harness and hook it to any +12v source coming from the radio that's only on when the ignition switch is "ON" (i.e. blue amp remote wire, power antenna lead from aftermarket radio, etc.)
The factory sub is not a powerhouse, but it's better than nothing. It doesn't sound too bad if it's still in good shape.
· Registered
cool thanks, i'll give it a try
