have you checked the coil? its unlikely but at least its a little more likely than the ecu going bad... other than that run to the JY and get an ecu and test it out.
CorrectHis is a GenB though. That ECU wont work.
I nocked it loose while working on it and it threw a code. Snapped it back togther and was good to go. I don't think its the o2 but ill give it a try.In addition to what has already been suggested, maybe your O2 sensor or wire is shot.
Are these located threw out the engine bay?Or bad ECU grounds...
Ditto. Otherwise you shouldn't have problems pulling the codes, right?i still say ecu is [shizzle].
Ya thats what I think also. Its just tough because it happens when it wants. Sometimes it will happen twice a day sometimes it wont happen at all. I threw my stock chip in to see if that has any effect and so far it hasn't messed up and I drove quite a bit yestarday. Next will be finding a computer. Thanks for the input guys.Ditto. Otherwise you shouldn't have problems pulling the codes, right?
