Hi hope some one has some answers for me, I'm having trouble starting my mazda mx6. I drove one night to the shop and came back next morning it was miss firing. There is spark and fuel, struggled with it and got it started but idling was very high, so i let it idle for some while and switched it off and didn't want to start after. Sounds like it wants to start when you start swinging but then nothing?
pull the engine codes:
FAQ: How to check the Codes and Code Numbers
Check the intake system for air leaks, check every vacuum hose for cracks.
Is your car non turbo? if so make sure to check the vacuum hose going to the distributor.
Are you running NGK ZFR6F-11 spark plugs?
