' 89 PGT
So here's the story...IR went on my alty..no big deal, i'll get a new alty.
So as im sure you all know, getting that sucker out of the engine bay was FUN! :tdown:
New belt and all that jazz too.
Belt was squeeking this past week, wasnt sure why...checked the tension, seemed okay..1/4" deflection..
Last night...belt blew :( and it decided to take part of my AC/PS belt with it.
Why would a brand new belt blow?
Sounds like it was to tight or the pulley is damage and is causing the belt to hit on the pulley.
did you go back and get the belt after it "blew" off? did it shred off or just suddenly snap? When I had my old alternator I was driving home one day and it sounded like my belt just snapped and I barley made it home before she died. The belt snapped because I had it too tight. However, if it shredded off that would indicate that there is a problem with the pulley or the belt alignment...
I would buy a new belt, put it on and double check the tension. Start 'her up and turn your heater and lights on. if it squeals like a stuck pig, id tighten the belt. If not, drive it and see if it happens again. If it does I'd take the alt back out and look at the pulley. I know gettin an alt in and out of there is about as fun as eating tacks, but 2 belts broken would indicate a bigger problem....especially if when you were wiggiling the new alt into position (trust me, lol, i know...) you could've hit on something that could have chipped the pulley, which would cause it to eat up belts...
just some thoughts.....
The belt was gone by the time I got home and checked. So I really couldn't say for sure, but I would say it just broke. Is there a good way to check for pulley alignment? i.e. alternator and crank pulley alignment.
You should not need to align anything. if your alternator bracket is fine than it shoud only be able to bolt up aligned.
Could be a defective belt. Also check to see if the alternator pulley is wobbling when you spin it. Could be a bent shaft as im sure you bought a cheap reman. ( I did and its working fine).
Would help if you had the belt because you could see if its frayed or just broken.
I would say belt was too loose and that is why you heard the squealing. New belts sometimes need to be rechecked for tension after a few miles of driving. Put on a new belt drive a few miles. Then retighten. Squealing usually means a loose belt. While it could be the pulley and such but if the pulley was not spinning then your charge light would have been on.
