Hi All,
I'm looking to buy either a MX6 88-89 or a 626 Turbo...
I have a couple of short questions for you:
1. Is the 2 door much lighter than the 4 door?
2. Is the suspension/brakes the same
3. Seating and interior comparable?
4. How bad is the torque steer at around 10psi?
5. Is there a LSD fitted?
Many thanks for your help, hopefully I will be purchasing the car in a couple of weeks...
Spectral.
cant answer all the question but ill try,
1. should be, the Mx6 shorter, by quet a bit
2. susp is same as far as i know, only Mx6 has more sporty feel
3. Seats are different but the dash is the same, so is center console
4. Don't know
5. a deffinate NO, but the drive sysstem is made very well so LSD would not be too much improvement
Corrections are more than welcome.
I hope you find right one Spectral
Thanks for that Blind Freddie...
I had a drive of a 88 626 Turbo and the torque steer was present but no worse than my '83 EXA turbo.
I guess once you have driven a FWD turbo, you get used to it :) Hopefully I'll pick up a 4WS model which might eliminate it further.
Thanks again..
Spectral.
im not sure that 4WS will eliminate it. WOO need help on this one.
G'day spectra
You can go to www.mazda.com.au
on the net and compare the MX6 and the 626 turbo, look under the heading 'Earlier models'.
Good luck
PK:)
G'day spectra
Good luck
PK:)
