Not a possible issue on 95+ computer as they use the crank sensor for trigger angle which is not adjustable. Yes, this applies to OBD-I 95's and all OBD-II.ryden_40330 said:check timing
ive seen a few probes and 626 v6s (Kl03) all ideling at 800rpm.Alein said:King6 not to disagree but 650 is suppose to be the proper idling rpm. Mine is set to 650 give or take a bit and it idles perfectly, 800 rpm would be getting into the start of a high idle I think.
Just my thoughts on it is all
Other than my 2g for other reasons, I don't think I've ever seen a 2g where the idle did not change slightly for a moment when fans kicked on.shorts6174 said:If the fans cause your idle to drop yoou have other problems.
friggen crap... i have issues then... im idling at like 1250...and when the motor is cold, it idles at 1500 i know that is high, but i thought 1000 was a good rpm, i see a lot of cars idle at that...Fastest95PGT said:I believe the stock idle is defined by the factory as a range of 650-800rpm.
