1 - 13 of 13 Posts
Does anyone have a wiring diagram for the new Halo pod headlights? I have searched but didnt find anything.... if anyone even knows where I could find one please post!
PS... I'm not just talking about the halo part... im talking about the Complete Headlight assembly... the hi beams low beams parking lights and halos
aren't there just two wires that u have to connect for the halo's???
If so then u can connect them to anything close by...like the turning signal...
let me know if u need help hooking them up, i've got mine up and running... i have pics in the appearance section of 2g mx6... check em out.
Its easier for a copy and paste hehe.
MX-6 Headlight Wiring Diagram (The Halo lights come with H4 type socket)
** The easier way is to go to local auto parts stores and buy the H4 light sockets. Then just swap the OEM socket with the H4 socket and plug it into the halo socket.
Or you could do the following:
On the factory plug:
1. Red/ white wire = high beam
2. Black/ red wire = low beam
3. Black/ yellow wire = ground
On the Halo headlight plug:
a. Blue wire = high beam
b. White wire = low beam
c. Brown wire = ground
Now, if your car’s plug doesn’t plug directly into the aftermarket halo light plugs, you will have to do your own re-wiring.
Tools needed:
1. Cramping tool
2. 6 large female connectors ( the ones that will fit the halo light plug)
Step 1: Cut off the plug on the OEM headlight wiring
Step 2: Connect the connector to the OEM wires
Step 3: Now, just plug in the 3 OEM wires to each plug on the halo light
• Red/ white OEM wire --- Blue halo wire plug (high beam)
• Black/ red OEM wire --- White halo wire plug (low beam)
• Black/ yellow OEM wire --- Brown halo wire plug (ground)
Step 4: The red wire (w/ fuse on it) from the halo lights goes to the positive (+) of the battery
Step 5: Check your wiring, and turn on the lights to see if they work. Make sure that you tape up and seal the connections with electrical tape after everything is checked.
As for the halo rings, I found it easier to just hook those up to the bumper light wires !!
help
does anyone still have the diagram?
thanx ruby, im trying to find the parking light or bumper side marker wires... can u tell me where they are?
1 - 13 of 13 Posts
