1 - 9 of 9 Posts
hi i have a uk 323 f v6
(cue laughter ;) )
i know about adding the cams from the 2.5 klze to get a lil kick, would the throttle body be a good move to?
any others know any trick mods apart from super charging and turboing
There's no standard KL 323F BA. A good route to take for a proper increase in power is an KF to KLZE complete swap.
You can gain a tiny bit of power by removing the pipe from underneath the airbox (not the intake! :)).
Mark
id say ZE also, insurance wont know the difference. you can play with the little bits and pieces all day and only get 15whp but with a ZE its 30whp straight off the bat.
I found a good increase with a s/s exhaust, cold air feed with a cone filter and best of all a high performance external coil with separate ignition. This last one is easy to do and does make a nice diff. A lot of us over here run with a fse as well. Boosts the fuel pressure to 1.7 times.
whats a FSE? and how does increasing the fuel pressure on a N/A car that already runs too rich on a factory ECU help?
1 - 9 of 9 Posts
