seriously considering a 50shot system in the spring from what ive been told if not used often stock interals should be ok any input would be good thanks guys
The Full Dong
a 50 shot on stock interals will be fine. From what I understand that is the MAX you should go with the stock fuel setup. There are many people between here and Probetalk who run a 75shot with proper fuel support.
So if i were to get a bigger fuel pump, could i use a 75 shot with stock internals and everything will be ok??
The Full Dong
fuel pump, FPR to start. I would do some research here and on PT. This has more than likely been answered. I
