I was recently told (by the dealer) that I need a oxygen sensor and an airflow meter. Is there more than one o2 sensor on the car('94 2.0L 4 cyl) and if so how do I determine which one to replace? Also how hard is it to replace an o2 sensor & airflow meter? Is it a DIY job? Pleas help. Kevin
what make him come to the conclusion that you need these items???
pull your malf codes and see for yourself.
but on the 4, there is only 1 O2 sensor, its relatively easy to replace...
and the MAF is pretty easy too... just not so much on the wallet...
Yep, 99% chance you don't actually need a mass air sensor. At worst, you might need to clean it. Get some brake part cleaner and gently spray the sensing elements a couple of times. Let the thing thoroughly dry and put it back on the car.
