1 - 9 of 9 Posts
Can I put OBD II in my 92. mx6 with OBD???
I want do see visual diagnostic on my 7"...
what I will need to make that happen?
you'd need to change your ecu, wire harness, get an obdII exhaust with O2 sensors, etc. if you don't want check engine lights :p the exhaust part isn't necessary but it will give you codes
oh yeah, the disty is different from OBDI to OBDII also. My 96 mx6 has a different cap/rotor than my 93 mx6.
well ... that's pity ... but - maybe someday, when I'll have some crazy ideas - I'll do it :) ... thanks for help everyone
i do have an obdII wire harness, ecu, distributor and stock exhaust that I could sell you.... only problem is you're in latvia :p
if I make that swap - I will have to tako off fender? ... and postal services could help us :D...
1 - 9 of 9 Posts
