Trying to weed out another gauge issue on my 91 MX6 GT project car. This time it's the coolant gauge and its odd behavior. The gauge itself now works (it originally didn't) but as the coolant temp rises, the needle will settle at exactly halfway between C and H and not budge even a fraction of an inch until I turn the key off. I have been driving GD cars for over 20 years now and I have never seen one that do that. I would expect the needle to move just a bit with whatever driving conditions I am experiencing, but not this one. I also am trying to relate this issue to when my fan is supposed to kick on. I know the temperature range the fan is supposed run, but I never hear it kick on in this car. Of course the fan runs fine when the A/C is on but that's a different scenario. I ordered an infrared temp gun to check what temp the car is running just sititng there...more info to follow based on those results.
Why is every car related F2T issue you have with these cars never simple to figure out. Or is it that everything I can figure out, you can to and solve all the other issues yourself and never post them.
I have been thinking about what could cause the gauge not to sweep properly and what would cause the fan not to kick on.
At first I though maybe a ground somewhere was affecting them both but.
The cooling fan and temperature gauge are two separate systems.
Info and tests.
The cooling fan is triggered by a water thermo switch on the thermostat housing.
On the A-spec the thermo switch cuts ground at and above 97*C (177*F), On the B-spec the thermo switch supplies at and above 97*C.
The A-spec runs a Normally Closed fan relay and the ground signal from the thermo switch is used to keep the relay coil energized and the fan off. To test the cooling fan and relay, turn the key on and disconnect the fan thermo switch, the cooling fan should come on. To test the thermo switch, with engine temp at or above 177*F there should be no ground signal at the male spade connector on the thermo switch.
The B-spec runs a Normally Opened fan relay and the ground signal from the thermo switch is used to energize the relay coil and turn the fan on. To test the cooling fan and relay, turn the key on, disconnect the thermo switch and ground the pin in the single wire connector (harness side) to a ground source, the cooling fan should come on.
To test the thermo switch, with engine temp at or above 177*F there should be a ground signal from the single pin connector inside the thremo switch plastic.
Temperature gauge uses the straight pin thermo sensor next to the distributor, this sensor delivers a resistance to the ground signal it gets from the rear housing it's screwed into. As the temperature increases the resistance drops.
B-spec US: 215 Ohms at C, 8 Ohms at H.
B-spec Canada: 215 Ohms C to 15 Ohms H.
A-spec analogue: 233 Ohms C to 16 Ohms H.
A-spec Digital: 177 Ohms 1 dash to 17 Ohms 10 dashes.
I don't really know what effect adding resistance to the ground signal in a direct circuit 12V system but I have read that DC voltage flows from ground to positive (exactly the opposite direction every diagram shows) and will assume it has the same effect as adding resistance to the positive wire.
So to test the temperature gauge with a first gen, disconnect the coolant gauge thermo sensor, take an 8 Ohm resistor (5 or 10 watt, 430 /860 Milliamps, not sure of the amperage requirements of the ground signal going to the gauge but the only thing at risk is the resistor), (15ohms for the other types of gauges should be fine),connect one end of the resistor to the wire with metal loop that was connected to the thermo sensor and ground the other end of the resistor to an engine ground point (nut, bolt, housing you get a ground signal on a multi meter close to the sensor). Turn on the key and the temp gauge needle should be at H.
There is a good chance that the temp gauge wire could simply be grounded to get the temp gauge to read H (max) but for the cost of a resistor I wouldn't bother risking anything.
Also a potentiometer/variable rate resistor within the gauges specified resistance range could be used for full sweep gauge testing.
The factory workshop manual recommends holding the resistance steady for a couple minutes and make sure the gauge readings stay constant.
Thermostat.
So what could cause both the cooling fan and temp gauge not to function properly at the same time.
Or what if they are both functioning properly, what could cause the temp gauge to never go past half way or even move and keep the cooling fan from coming on. Too cold rating on the thermostat, weak or tired thermostat that opens to far could keep the engine temps from reaching 177*F and turning on the fan.
A single stage low temp thermostat could cause both these symptoms also.
A properly working 2stage T-stat would definitely cause the temp needle to move between stages.
The 1992 Mx6 GT I drove years ago had a problem getting up to proper operating temp. It had to idle a wile and as soon as I would start driving it the temp on the gauge would drop and the car would go back into warmup mode and the cooling fan never came on. I dropped some coolant and pulled the thermostat housing expecting not to find a T-stat in there but it was there covered in a pile of red gasket maker and jammed opened. The gasket maker must of jammed up the passage enough for the coolant to reach 100*C (212* F) and open the thermostat fully, then jammed it there.
