1 - 15 of 15 Posts
Was on the freeway and decided to do a pull to see how nice the boost held with the new wastegate, was set at 1 bar (14.7psi), pulled very very nice, but about 3 seconds into the pull the car stuttered for a sec, then kept pulling, so being the cautious person I am, checked all my gauges, lights, all read fine, so I just stayed out of boost until I got home. When I got home, I noticed around my BOV, there was a nice array of oil splattered around it, and when I wiped it down, it was a decent amount. And usually I hear a bubbling noise when I shut it off (the oil in the feed line/turbo just being hot) didnt hear that anymore, but I did hear the sound consistint with your faucet when you let it drip water, it was pretty distinctive, yet there were no leaks under it, and to top it all off the car isnt smoking so that rules out the piston rings. The car is seeming to be dropping the oil at a decent rate, yet no smoke coming from it, or leaks under the car. I can only assume the turbo seals are going out, but at that it would smoke, unless its only coming out the compressor side?
:shrug:
Take of piping or hose from the compressor side and check if theres oil in there but sounds like the turbo oil seal is on its way out.
Cover that blue anodized TurboXS ROFL valve with a hose and route it into your valve cover 4 teh Ngyuen.
Ya! Ill do that once you cover your mouth with a hose and route it into your butt cover 4 teh Ngyuen!!!1!one
Useless post...
But...
Keeloh thanks for the reply, I was thinking that too, just wanted to see what others thought.
This is a public forum. If you don't want or can't handle replies even as jokes, then maybe you shouldn't post. ;)
Your right this is a public forum, if you don't want or can't handle replies even as jokes to your joke then maybe YOU shouldn't post.
Congratulations, you have steered this thread OT. ;)
Oh and FYI...
There is a Joke section for this shit.
But...
I do appreciate the response though, it totally helped troubleshoot my problem. :tup:
This can be closed, I can tell this thread direction is already going to turn into a storm, guess I will have to go elsewhere for help. :shrug:
I lol'ed
But yeah, if you're oil is coming out your bov, there's only 2 places it could be coming from: crankcase vent or the turbo seals.
So, why don't you vent your crankcase to a catch can, do a few pulls, and check out the can/bottle/what ever and see if there is oil there or still on the bov.
I know that valve cover can see some pretty decent pressures at high boost. My compression is 145-150 across the board and my valve cover seeps some major oil if i drive it hard. - Doesn't leak a drop while parked though. I def need a new valve cover gasket. :sigh: more money to spend...
My catch can get oil like crazy everytime i punch it.
haha, tempting. I'm pretty cheap, but idk about buying used gaskets haha
Discussion Starter · #15 ·
Fixed the problem, the new PCV I just bought was broken (funny new doesnt always mean it works lol), after looking at it because it was the only thing changed recently it was snapped in 2 thus being always closed and the reason for the high crank case pressure forcing everything into the before turbo side exit.
There is still minor oil coming out of the bov (nothing like before) but that could be because I now have a bad valve stem seal in cylinder 3 due to the pcv failure earlier. (Car smokes at idle and thin smoke during load or WOT)
1 - 15 of 15 Posts
