Ok, I was at autozone today buying some new plugs, wires and distributor parts, we went out to make sure that the spark plug socket that I was getting would fit in the spark plug recess, and he stuck it down there, and it came out covered in oil. When I got home, I checked the others for the same thing. It turns out that cyl. numbers 1,2 and 5 have the same symptom. the guy at AutoZone said that it was probably "tube seals" and that I would probably have the valve covers off to fix it. Has anybody had this happen to them? What was required to fix it. Also, I diagnosed my engine, and got the number 8, and either 2 3 or 4 codes. It seemed that the blinking of the engine light was a bit erratic. The engine starts with the key, so code 4 is not an option, so it is either 2 or 3. I am thinking that it is most likely 3, so I will inspect that some tomorrow. If you have any advice, please let me know. Thanks
