Here goes folks,
After installing a ball bearing T3 (from RB25DET), there is oil making its way into the compressor housing and a some of the intercooler piping.
Now, before anyone says its the PCV, its not. I have that vented via filter to make sure that wasn't the cause.
I have the oil feed going in by a banjo bolt, with the bolt itself having an approx 1.5mm hole through it, as a restrictor. This is standard with this turbo. The temporary oil drain, however goes to the standard drain hole in the block and the angle isn't very steep. It's just steep enough for oil to run down, but I plan to put it into the sump when i get the time.
I have 2 of these turbos, both of which have done the same thing. I'm pretty sure the seals on both turbos are good, because when I inspected them, they were clean with no oil inside (you can tell they weren't cleaned and degreased because they weren't sparkling and had a bit of dirt and residue on it like a normal turbo of that age would have). Both turbos had no oil going out the exhaust. No funny noises. Boosted very well, just this oil is shitting me because I dont want oil to get in my new intercooler and piping.
I've done a bit of reading and this is the best thread so far:
http://www.mx6.com/forums/2g-mx6-forced-induction/200557-restrict-not-restrict.html
Could it be high oil pressure? (even though I have a restrictor. Warm idle is 25, and boosting/revving is 55-60 PSI)
Or could it be the 'shallow angle oil drain'? Does this cause oil to back up and pass through the seal in the compressor?
Thanks in advance for comments/advice.
UPDATE: I just remembered... before bolting in the oil feed, I had topped up the turbo with oil (accidently, i didn't mean to pour that much), so it was lubed on start up. I got the spare turbo and poured oil in it and waited 5 mins, and none had dripped from the drainage, it was still sitting in the top.
Now is it possible if the oil cavity in the centre cartridge is full, then you start the car and 50PSI of oil pressure coming from the feed is trying to make its way in, but has no where to go in such a short time, that it forced itself passed the seal and into the compressor? Can that happen?
