1 - 16 of 16 Posts
I didn't change my clutch when I changed my gearbox and the clutch must have oil on/in it from when my other gearbox died, so when ever I push it hard like over 6psi it just slips unless I back off and let it grip then I can floor it but.
Any ideas on what can be done without getting a new clutch? I was thinking of flushing it with kerosene, would this damage the clutch? it might get in the throw-out bearing :(
HotAss6GT said:
well that's good :)
no, it isnt. haha. its still bad zach. regardless, even if it was the rear main, its not that hard to replace it if the trannys off anyway.
TX5F2T said:
If it has to come out I may as well get a new clutch plate :/
why? if you can just clean it and save yourself $150+ why wouldnt you do that, if the clutch otherwise is fine. [I mean, if its beat to hell anyway, then yea get a replacement]. Clutch replacement isnt THAT big of a deal... are you doing your own work?
i know it's still bad....but better a worn seal in a transmission than your rear main seal that can cause other havoc...lol
I'd rather it be the rear main...don't have to take parts of the transmission.
-Andrew
-Andrew
exactly. take off the oil pan [so that you can ensure a good seal] and bam, its cake. done, and done. probably as easy as a throwout bearing replacement.
[at least on the mr2].
1 - 16 of 16 Posts
