It seems I have an oil leak. It was coming from the front and rear bank of the motor so we replaced the cam seals, valve cover gaskets, and intake gaskets, but it is still leaking from somewhere else. we let the car warm up in order to fill it with radiator fluid, and it was on a cold night so that took a while. No leak. Then we drove it up to the store and by the time we stopped there was a huge puddle of oil on the ground. It seems that it starts to leak really bad around 4,000 rpms. Also this is the second oil pump on this motor, so i don't think it is that either. Has anyone else had this problem or a solution. Thanks for all the help.
Chase
shampoo the engine really good then take the car out for a quick spin and when you come back just trace the oil back up the engine to wherever its coming from
